Diesel Newbee
- dpalmer
- Cardinal Owners: 2018 3456
Diesel Newbee
We are getting ready to head for the Klamath rally and it will be our first trip towing with a diesel.
Questions
How often will I need to add DEF while towing
Do you carry additional container of DEF
What kind of mileage should I expect with the 6.7, 3.73 dually
Excited to get on the road
Questions
Dave & Karen
2018 3456
2021 F350 XLT, 4x4 Dually
Rallies Attended = 22 and 3 F.R.O.G.
Full-time as of 10/1/2016
2018 3456
Re: Diesel Newbee
DEF is available just about anywhere, I have never calculated how much is used while towing. I know that you are good for over 1200 miles with a full tank. I tow 600 miles one way to NY every year and have never added DEF until after I am home. Then I do not completely fill the tank because freezing temps are getting close.
- tecosinc
- Cardinal Owners: 2016-Cardinal 3850RL
Re: Diesel Newbee
I have a 2014 ford drw w/ same Motor and gear ratio as yours. I pull a 3030rs. I make 10 mpg on the average. I put def fluid every thousand miles. I'm sure you can go longer on def, but that's what I do. I don't carry the def fluid. Usually get it at Auto zone. Good luck.
Errol & Tina Jenkins
2016-3850RL Full Body Paint
2020 Ford F350 King Ranch FX4 DRW w/ air lift bags
Nights Out-2015-59
Club Rallies Attended-2
FROG Rallies Attended-2
Nights Out-2015-59
Re: Diesel Newbee
Although my truck doesn't use DEF I have seen it available in the fuel lanes at Pilot and other truck stops. Friends with trucks using DEF also have said its available at Walmart for a reasonable price.
- dpalmer
Re: Diesel Newbee
Thanks for the info, that is all helpful
Dave & Karen
2018 3456
2018 3456
- dennis1949
- Cardinal Owners: 2016. Blue Ridge 3045RL
Re: Diesel Newbee
Save your empty DEF jugs. When you fill the truck up fill the jugs up also. This will save you 3 to 4 dollars a gallon on the DEF This way you always have some DEF if you don't stop at a truck stop
Dennis Carpenter
2012 3/4 GMC Z71 truck
Decatur Al.
Decatur Al.
Re: Diesel Newbee
I always take off with 3 gallons that I have filled at the dealer. It will take the 3 gallons after about 2,300 miles of towing. Once I use them I usually go to O'Reillys and pick up a few gallons of Peak Blue.
Re: Diesel Newbee
Dave, the computer on my Chevy will allert me when DEF is getting low. It will say something like 250 miles or so before it runs out. This gives me plenty of warning to give it another drink. I usually just add one 2 1/2 gallon jug from WalMart, and go until it tells me to get another.
Dale
Dale
- Cardinal Owners: 2019 Cardinal 3456 RLX
Re: Diesel Newbee
My 2014 Ram has a def gauge. When it gets down to just above a half on the gauge it will take 2.5 gals. Bought the truck last August and with 6k miles empty and towing I have only added 5 gals. I plan on carrying a 2.5 gal of def along on our trip next week but as was posted def is readily available. I would hope that the price at most retail outlets will come down Def is deionized water and ammonia. I honestly believe that def makers are taking adavantage of the market. Way overpriced compared to bulk. Average cost in Oregon is $13 per 2.5 gallon versus $3 per gallon at a truck stop using the truck pump ( w/ PUC)
Mike & Sandy
2019 Cardinal 3456 Luxury Edition
2018 Ram 3500 4x4 Crew Cab Aisin 6spd Dually
- dpalmer
Re: Diesel Newbee
I think I will pick up a 2 1/2 gallon at Walmart and have it with me for piece of mind. If it is due and I am fueling I will get it at the pump. The info of your experiences has really helped this new diesel owner, thanks
Dave & Karen
2018 3456
2018 3456
- Cardinal Owners: 2013Cardinal 3030
TV 2020 Ram 3500 4x4 HO 6.7 Cummins - Location: California Ramona
Re: Diesel Newbee
When you buy it at the truck fuel islands you may need a magnet to put on the nozzle . The big trucks have them built into the tank. It is to keep from putting it ito the Dieseltank. You can get them oline if you need one. Msybe tHE FORD TANKS HAvE OnE BUILT IN.
- dpalmer
Re: Diesel Newbee
I had to add DEF once but used the jug I bought, The Pilot we stopped at was intimidating with trucks lined up behind me and wasn't sure how to get the DEF The sign said push here for DEF so I just left. I'll have to see about the magnet. thanks for the tip.
Dave & Karen
2018 3456
2018 3456
Re: Diesel Newbee
I am sure some of the people who own the newer diesels will be along to explain what they do! I have no idea since my older model Dodge does not use DEF.
- dpalmer
Re: Diesel Newbee
I am sure I will get all the info I need when we reach Klamath
Dave & Karen
2018 3456
2018 3456
