I got a recall letter from Forest River on Dometic Refrigerators. If you haven't gotten a letter and have one of these listed you might want to contact Forest River or call 1-888-446-5157.
Affected Units:
The potentially affected refrigerators have the following model numbers:
NDR1062, RM2652, RM2662, RM2663, RM2852, RM2862, RM3663, RM3862 and RM3863.
The possibly affected units have serial numbers beginning with the following conbinations:
713xxxxx through 752xxxxx
801xxxxx through 852xxxxx
901xxxxx through 952xxxxx
001xxxxx through 052xxxxx
201xxxxx through 252xxxxx
301xxxxx through 319xxxxx
Merry Christmas Y'all
Forest River Dometic Refrigerator Recall
Forest River Dometic Recall
I just got this in the mail today so I'm guessing it's a new recall.
It is a safety recall.
It states,
It states,
The Problem: A fatigue crack can develop in the boiler tube on the identified refrigerators, which can permit the release of pressurized coolant solution. If this solution is exposed to an ignition source under certain specific circumstances, it can result in a vehicle fire.
Tinner...thanks for the info. This link can be used to check the model and serial no. of your unit and Dometic will advise you if your unit is affected by the recall. http://www.dometicusa.com/recall.php
- bayoubengal
- Cardinal Owners: 2008 31RKLE
It's the same recall that has been around for over a year. I'm sure by now most folks have had the fix done on their refrig. FR is just covering their butt.
Vince & Kim
2008 31RKLE
Nights Camped:
'02--74 '06--122 '10--24
'03--59 '07--47 '11--44
'04--83 '08--98 '12--76
'05--99 '09--84
2008 31RKLE
Nights Camped:
'05--99 '09--84
