jjames1942 wrote:Mountain driving isn't all that bad. I usually put my dodge in 3rd or 2nd depending on the downgrade, and only brake to keep the rpms under redline. This seems to work well for me. Always check your brakes before the down grade and start the downgrade as slow as possible. Stay away from the 10% downgrades. Those can really be exciting. These downgrades are usually on the two lane roads with no shoulders. Good Sam sells a mountain downgrade directory which gives the downgrade and length of the downgrade. It will help you decide which roads to take. Once again stay away from the 10% downgrades. Good luck.
Mountains are not that bad, I agree. As I live, work and tow the 'Bird in the Sierra Mt's here are a couple of pointers I use myself.
1. Know what downgrades you'll be facing. If there are steep downgrades along a truck route, the state will post signs for "Brake Check Areas".
2. Never start at the top of a steep grade faster then the posted truck speed. If a truck speed isn't posted, stay under 40 mph or less to start. Lots of curves or reduced visibility due to blind curves, especially on a two lane road, I'll do 25 mph. Always be aware in steep terrain there is the possibility of rocks, etc on the road. Or the 'Wanna Be a Rally Driver' who just might be in your lane coming the opposite direction. Keep an eye on the mirrors. If traffic backs up more then 4 or 5 vehicles, pull off at the next turn out and let the traffic pass. Also do this on steep UP hill grades. In mountain states "It's the LAW".
3. Gear down, even with the new automatic transmissions. On both of my Fords since I got the 'Bird (ie: HEAVY TRAILER) I've used 3 as a rule, but there are times when 2 is required.
4. DON'T RIDE THE BRAKES! THEY WILL OVERHEAT AND FADE OUT! If short applications of braking can't keep the speed down with the gear you selected prior to starting downgrade, slow to a stop before things get out of control. Then select a LOWER gear. My rule of thumb is if the gears can't keep it within 10 mph of what ever speed I selected with short applications of the brakes, it's time for a lower gear AND A SLOWER SPEED. IF your brakes start to fade STOP NOW at the first sign of that. If there is a turn out or wide shoulder, great. But STOP. NOW. Give the brakes plenty of time to cool off. I've discovered over the years that it is better to start with too low a gear selection when I'm unsure. The ONLY TIME for constant brake pressure IS COMING TO A COMPLETE STOP. PERIOD.
5. Take your time. A truck and trailer are not sports cars.
Enjoy the scenery you'll see at the slower speeds. I'm always seeing things on roads I drive without the 'Bird at speed that I notice when I'm taking my time with the 'Bird in tow.
