We have a 08 Chevy Duramax 2500. We have 23,000 on it. Since it’s been new there has been a chirping noise in the engine. I’ve had the dealer look at it and he told me it’s normal. I’m not buying it, and was wondering if those that have a similar pickup are running into the same thing?
2014 Ford 350 King Ranch, Trailer Saver BD3 Air Hitch, IS Suspension, Disk Brakes Nights camped in 2012: 142
'08's have a history of engine chirp which is caued by the belt. Does not seem to be an issued other than noise. Some folks have reported the issue being resolved by using a NAPA or Gates belt.
David & Pam
2006 Cardinal 31RKT
2002 2500HD Duramax
This likely doesn't directly apply, but may be of interest.
"Noisy Duramax Diesel… Some may question why the
owner of a rattling and compression knocking diesel
truck would complain about a minor belt chirp or squeal.
Accessory drive belt noises involving belt squeal, squeaks
and chirps have plagued the 2004–2005 Chevrolet
Silverado and GMC Sierra trucks fitted with the 6.6L
Duramax diesel engine. The condition occurs during a
cold start-up, and may continue until the engine reaches
its normal operating temperature.
For a belt noise condition, the first check should involve
a belt-to-pulley alignment check. Verify that the power
steering pump pulley is pressed onto the pump shaft in
the proper position. While the pulley should be flush
with the end of the pump shaft, it can be repositioned on
the shaft to achieve the proper belt alignment. The pulley
to shaft position variance should not exceed 0.039 inch
from the end of the pump shaft (see Fig.1).
TROUBLESHOOTING BELT NOISE
Installing a Second Belt Is Not the Solution
Some of the mentioned
trucks produced prior to
June 2004 may have an
AC compressor/power
steering pump mounting
bracket and rear power
steering mounting bracket
machined slightly out
of spec, resulting in a
misaligned power steering
pump. If this condition is
present, the drive belt will
be out of alignment with
the fan pulley, resulting in a chirping noise. When the
belt leaves the fan pulley, it will not be in alignment with
the crankshaft pulley, creating the belt noise condition. A
revised bracket is available from GM for those vehicles
produced prior to June 2004.
Vehicles produced after June 2004 have the revised
AC/power steering pump mounting bracket. The rear
power steering mounting bracket on all vehicles prior to
and after the mentioned production date may require a
modification. This modification involves drilling larger
holes into the rear mounting bracket to ensure proper
alignment when installing the mounting bolts. GM TSB 05-
06-01-018 illustrates the proper procedure and necessary
mounting bracket part number, where applicable.
Be aware that a belt chirp noise may be present during
engine shutdown on any diesel application, and this is a
normal condition, with no repairs necessary. The noise
condition occurs due to the high engine compression
and rapid deceleration of the crankshaft and drive belt
during engine shutdown, and this condition cannot be
eliminated." mightyautoparts.com
hmmm I have not heard a chirp sound in mine yet almost 35k on it. I do notice a lot of noise when the oil pressure is up do the oil being cold in the morning but that is about it. Like George said when does this happen? Normal driving or under a load, I do not use my air conditioner much in the winter unless i am defrosting my windows when I have it on auto I make sure the AC is off. Let us know when this happens and I will see if I can duplicate it on mine.
2019 Silverado 3500HD Dually D/A 4x4 LTZ My dreams are too big for my wallet Rallies attended - 32
I'm hearing the noise anytime I'm outside of the truck and it's running. Can't hear it inside. Doesn't matter what the outside temperature is, or if it's been running for a while or just start it up.
I know what your hearing George Guess I should be nice he is going to have a drill in his hand around my trailer
I wish I could hire a driver when we go camping and just show up when its parked.
I hear and feel everything while driving and always wonder WHAT IF, and the what if drives me crazy.
Oh well even though it really stinks when something breaks it just turns into another adventure.
Mike Clay wrote:Oh well even though it really stinks when something breaks it just turns into another adventure.
True---and in the sport of Rving there is always something that needs to be fixed. I guess it's part of the fun---well sometimes.
