Water leak in 30WB bedroom slide
- Cardinal Owners: 2005 30WB
Our 2005 30WB has a water leak coming from the bedroom slide and showing up on the floor next to the shower. The dealer has worked on this twice (under warranty) and it is still leaking. Has anybody else had this problem and if so how was it fixed? Any help would be appreciated!
I had a leak in the big slide on my bird. I finally found the seal screwed to the slide, which seals the inside flange to the inside wall was bent. Using silcone fixed it. From the outside, look behind the rubber flap that goes around the slide, but mounted to the outside wall, to see the inside seal. I will get the seal replaced before the warranty is out.
Hope this helps.
Hope this helps.
- Skype ID: bill.bopra
you betcha,
Is the water coming from rain or from the shower?
The only leak we've had was rain water coming in from the antenna wire. The boot that fits over the fitting that comes thru the roof came off. A little silicone and all is well.
