Tank Heater
This is a forum that you can post things that cause or can cause permanent damage to your RV, i.e. isopropol alcohol will take off the finish in your sink.
Describe the problem in a straight forward manner and PLEASE no replies to the posts!
Re: Tank Heater
I guess I am not following you what is easier?
bfast54
Re: Tank Heater
Post by bfast54 »
Well......If I am reading the mind/logic.........it appears to be "Easier" to leave the black tank valve open..............despite the obvious risk of building a "Black Mountain"....Which I understand is a Bitch to remove.
So, one can only be warned....and then do as one pleases. :))
EAW
Cardinal Owners: 2005 Cardinal 31RKT
Skype ID: eaward49
Re: Tank Heater
Post by EAW »
I believe CCC is saying that it is easier to flush the toilet if the hose is connected. I don't know CCC's model of Cardinal but if it is a "park" model, there is no black tank so you have to have a hose connected to use it.
A few years ago when we camp-hosted at a park that had a lot of people working on building pipelines and they claimed that they were living in their trailers, not camping. Many of them did not know about the black mountains they were creating by leaving the black tank valve open. I was only able to get a few of them to understand that they were living in a camper and some things were different.
RetiredFifthWheeler - now that the weather has warmed back up, how did you make out?
Earnie, Penny, and Roxie
Re: Tank Heater
He has a 3640RTS
RetiredFifthWheeler
Cardinal Owners: 3825FL Fifth-Wheel
Re: Tank Heater
Post by RetiredFifthWheeler »
EAW wrote:RetiredFifthWheeler - now that the weather has warmed back up, how did you make out?
I put some water in the fresh water tank, and closed the other tanks and stowed the sewer hose in the heated basement. I also disconnected the water hose and drained it.
It seems that everything is working fine this morning and we won't be seeing another below freezing night on this trip. We are back on the heat pump, lol.
Wayne & Ruth Spong
2016 3825fl
Good Sam Life Members
Rallies attended - 3 (+ 4 FROG)
EAW
Skype ID: eaward49
Re: Tank Heater
Post by EAW »
:thumbrt:
