slide out unlevel still
- Cardinal Owners: Cardinal 31RKLE
Hi folks: Well, we camped 4 nights after major warranty work on my slide out (see previous post). All went pretty well, but I have a question. My floor on the kitchen slide is still NOT level--it's better, but the table is noticeably unlevel compared to the rest of the rig. The dealer said it was fine. I'm thinking I might just shim the wall side of the table up level and forget it! Or, should it be level?
How many of you folks have the floor of the coach and slide both at the same "bubble" in the your carpenter's level? Thanx, Mark
Mark, What I would check would be to see if the facia board of the slideout is an even distance from the rig wall top and bottom. This will ensure you have a decent seal to keep out wind, rain, etc and keep your heated or cooled air inside the rig. The seal behind the facia board should not have gaps from the rig wall, but also not pressing hard enough to loosen the facia from the slide. If not even from top to bottom adjustment needs to be made at the outboard end of the slide out arms under the slide. If not sliding out far enough or sliding out too far (trying to loosen the facia) it will need adjustment at the outboard end of the slide out actuator rod (be sure to leave some gap between the nuts for hydraulic creep). Can someone provide the link to Mark for lippert slide adjustment? I am overseas again so don't have my favorites on this machine.
Bruce
Bruce
- Future Fulltimers
- Cardinal Owners: 2006 30TS
Mark, here is the page(s) Bruce is talking about. This is from the slide manufacturer.
http://www.lci1.com/service_owners_manu ... deouts.htm
- pops91710
- Cardinal Owners: 2006 30 WB LE
None of the manuals looks like my bedroom unit.Future Fulltimers wrote:Mark, here is the page(s) Bruce is talking about. This is from the slide manufacturer.
Mike Harrington, Chino, CA.
2006 Cardinal WB/LE 30'
- Future Fulltimers
One of these should be the proper one.
http://www.lci1.com/Service%20Owners%20 ... ll-Web.pdf
http://www.lci1.com/Service%20Owners%20 ... ut-Web.pdf
- pops91710
Future Fulltimers wrote:One of these should be the proper one.
No, I already saw those before. Mine has the ram down the middle of the slide-out's frame.
- Future Fulltimers
