jacks
This is a forum that you can post things that cause or can cause permanent damage to your RV, i.e. isopropol alcohol will take off the finish in your sink.
Describe the problem in a straight forward manner and PLEASE no replies to the posts!
kenny hodges
Cardinal Owners: 2003 31ts
Skype ID: no
jacks
Post by kenny hodges »
what kind of jacks are you guys taking along. and what size thanks kenny always carry tool box what else do i need to take?
Travelers
Re: jacks
Post by Travelers »
3/4" deep 1/2 drive socket with 4" extension and a breaker bar - in case you need to change a tire.
1 1/16" socket 1/2" drive for anode rod in water heater - incase you need to tighten it up.
Re: jacks
I carry a 6 ton bottle jack and short pieces of wood 2x4 and 4x4 in case the jack is to short to reach the jacking point.
Re: jacks
I carry a 10 ton bottle jack never have used it yet since i have my own pit crew
Double D's
Cardinal Owners: 2013 3675 Cardinal 5th Wheel
Re: jacks
Post by Double D's »
Well, yes you DO, Mike! LOL! And a FINE looking crew it is!!!!
Double D's - Dennis and Donna
Rallies - 20
Days out in 2015- 145
Days out in 2014 - 71
Days out in 2013 - 187 Alaska
bigbunkhouse
Cardinal Owners: 2007 362BHS
Re: jacks
Post by bigbunkhouse »
are those bfg's mike? what size you running? wheres the thunder guns if its a real pit crew? LOL
Re: jacks
Yes they are BFG commercial TA all season 235 85R 16 I think. Don't need a thunder gun when you have Roberts hands of steel. Don Wilson my Jack man and me as the tire carrier =))
Mojave Desert
Cardinal Owners: 2007 30WBLE
Re: jacks
Post by Chief409 »
What, no Fire Suits? =))
I have the socket, breaker bar, extension, torque wrench, 6 ton jack, pieces of 2X8, but for changing tires I have the pull up on tire ramp, which I haven't and really don't want to use. I did use the bottle jack and 2X8's to raise the front of the "Bird so I could hook up when I had landing gear problems awhile back.
Re: jacks
the ramp works ok on mine if you put it on some plywood first BUT DO NOT try to use it while on slick concrete.. That thing will shoot out of there like a rocket. :shock:
mike & linda
Cardinal Owners: 2013 3030RS
Re: jacks
Post by mike & linda »
Are you placing the jack on the frame or the axle?
2006 F250 PSD CC
2013 3030RS 5er (The Load & Go}
DW & #1 Son
Re: jacks
I place the jack under the shackle mounts for the leaf springs
Re: jacks
I use the "Trailer-aid" ramp. I carry a 2x6 to put under it because it is just a tad low. It works like a champ and you don't have to get under ther trailer to set it up.
bill
bfast54
Re: jacks
Post by bfast54 »
I carry a 6,or 10 ton BOTTLE-Jack........(cant remember which ).................just used it for the second time in its history a couple of weeks ago.........under the axle, between the spring bolts. I knew where I had stashed it, had it out a couple weeks before re-arranging things.......... :thumbrt:
mike & linda
Re: jacks
Thanks for the info. I am going to use the shackle mounts too. However, I have never heard of the trailer aid. It looks very interesting. I will have to get one of those. Have a Great 4th
2006 F250 PSD CC
DW & #1 Son
