holding tanks
This is a forum that you can post things that cause or can cause permanent damage to your RV, i.e. isopropol alcohol will take off the finish in your sink.
Describe the problem in a straight forward manner and PLEASE no replies to the posts!
kenny hodges
Cardinal Owners: 2003 31ts
Skype ID: no
holding tanks
Post by kenny hodges »
did not get owner manual with 2003 31 ts do any of you know the size of the fresh water tank and the black water and 2 grey water tanks ? thanks kenny
Re: holding tanks
All 40 gal. tanks.
Re: holding tanks
Fresh water may be larger than the three 40 gal holding tanks. In 2004-5 the fresh water tanks were 52-54 gallons. Chris
Re: holding tanks
Chris is correct on the fresh tanks, could be 54 gallons, 2007 went to 65 gallons, now 77 gallons.
Re: holding tanks
My 2004 built in September 2003 only has a 40 gallon Fresh Water Tank. I actually used 5 gallon buckets to drain and measure it.
kenny hodges
Skype ID: no
Re: holding tanks
thanks for the feed back kenny
