Bad day yesterday for my tv
Re: Bad day yesterday for my tv
Are you replacing all 8 pistons? I just re-read the string and see you will be doing major upgrades, obviously doing it right. It ought to be bullet proof when you are done.
yes all new HD pistons,Rings, rist pins, all lifters, head studs, egr cooler delete,all new injector lines from rail to injector. and the other stuff gaskets, seals,dfredendall wrote:Are you replacing all 8 pistons? I just re-read the string and see you will be doing major upgrades, obviously doing it right. It ought to be bullet proof when you are done.
I have to hone the #8 cylinder to make sure it will be ok if it is then I can order std. size pistons.
That is a little wrinkle but no melt
Some more pics of #8 piston
The hole in the top came out the side but it looks like it just busted out a small piece.
Looks like you came real close to destroying the block. Cylinder wall has to be scuffed a bit on the one side. Chris
Yeah I tryed to hone out a mark in the cylinder wall but I'm at 5 thousands clearance now and 4 is max so I have to strip the block and send it to be board out. Anothe $400
I got my new pistons yesterday took them to the machine shop I hope he can have it all board out and to me by tue, wed. next week, I also got the ARP head studs and the upper and lower gasket sets, the new lifters, and the egr cooler delete. so maybe late next week I will be starting to build the engine. I hope so I sure miss having a truck.
I built the engine mostly yesterday finished it today
Now that's s torque wrench the head studs get 275 ft/lb
Today put the engine back in and the cab back on tomorrow button it up and fire it up
- Cardinal Owners: 2006 Cardinal 30TS
- Skype ID: 30TS & Dodge
Look at the length of that torque wrench! How much torque do the head stud nuts get? I'm just curious. We had an automotive machine shop in Lee's Summit, Mo. That's what I retired from. I am really interested in your progress. Thanks for the pictures. Roy & JoAnn
Roy & Kay Studer
Head stud torque is 275 ft/lb it is running again I only have 6 miles on is so far. I had a fuel leak under the turbo at the high pressure pump I had to pull the cab again to fix it (was one loose fitting I did not tighen) but she is running and running quite well I must say.
Now you can get back to the Mods on your new Cardinal.
I had to move the bird to the storage lot before it snowed here the bird mods are on hold for now but I did oped up a garage bay at work she will fit in so I may be able to do the slide toppers if I get a chance but I'm swamped with other truck repairs right now
Great job Dave. I appreciate the photos showing how the engine stacks up. I still do not like the wimpy "O" ring gaskets of the bed-plate design. Mine were replaced under warranty at 35,000 miles for leaks, and are leaking again at 135,000. I am curious how much that rebuild/repair would cost a customer who towed their truck into a shop like yours seeking revival. Your talents are priceless. Glad you are back on the road.
Thanks I had 42 hrs in it I get $75 / hr to do diesel work I had $3900 in parts and machine work and close to $4000 in labor so $7500-$8,000
